Connect ZWO Asiair to Avalon Linear (Stargo)
  • ken.self
  • ken.self's Avatar
02 Nov 2019 20:53 #10 by ken.self
Replied by ken.self on topic Connect ZWO Asiair to Avalon Linear (Stargo)
Hi Daan,
I use INDI to control my M-Uno and contributed to the driver development along with Wolfgang and others.
You should just connect with a normal USB cable. The trick is getting the right serial port number, especially if you have multiple serial devices.
Normally the driver can work it out but you may need to set it manually. I'm not sure what functionality the ASIair provides. But try to follow the advice in the link provided by Christopher. You may need to Scan Ports and select it manually.
Also, the driver does not provide some initial configuration functions so you might need to do an initial setup under Windows.
  • Daan
03 Nov 2019 13:47 #11 by Daan
problem is solved :-)
In the telescope settings there is a pulldown menu in which you can select next to the "Avalon Stargo" mount also the mount "Avalon Legacy". If I select the latter it will indeed connect to my mount (USB A to USB B cable). If I select Avalon Stargo the ASI Air app crashes (freezes and closes down after some time).
I could not find any info about this in the manual nor in the ZWO forum. I'm using the Linear Stargo Bluetooth version. I guess the bluetooth version is being considered as legacy....
to all: thanks for replying :-)
  • sterne-jaeger
  • sterne-jaeger's Avatar
03 Nov 2019 21:04 #13 by sterne-jaeger
Replied by sterne-jaeger on topic Connect ZWO Asiair to Avalon Linear (Stargo)
Hi Daan,
I'm afraid that's not a sustainable solution. The Avalon Legacy driver is a very simple LX200 implementation, while the Avalon StarGO driver is far more StarGO specific.
If you provide the log files, I could take a closer look why the driver crashes.
Wolfgang
TSA-120 + FSQ-85 + GSO 150/750 | Avalon Linear + M-zero | Moravian G2-8300 + ASI 1600mm pro + ASI 294mc pro | INDI/Kstars on Raspberry Pi 4 with Raspbian 10
  • Daan
04 Nov 2019 10:25 #14 by Daan
Hi Wolfgang,
So the quest continues....:-)
Access to log files is not listed in the manual so I have to check with ZWO if a user has access to the log files. Most likely not because it looks user access to the ASI Air is limited to downloading images and the guiding log files....
  • ken.self
  • ken.self's Avatar
04 Nov 2019 12:31 #15 by ken.self
Specifically you want the INDI logs
Also, whcih version of firmware are you running? Ideally should be 566
  • Daan
04 Nov 2019 13:00 #16 by Daan
Ok, keep you posted upon ZWO replying to my request for the log files.
I'm running Firmware Ver 5.6.6, Stargo Ver. 5.6.43 and ASCOM V.6.8.2.63
Copyright ©2020 www.avalon-instruments.com - Design by Top 10 Binary Options
f t g m
Avalon Instruments
 Registered Office:
Via Angelo Secchi 8, Roma
Headquarter:
Via Pontina Vecchia KM 38,500 - Aprilia (LT)
CF/P.IVA 14949111000
Tel. 06 87153197
Terms of service
Secure Payment
paypal credit card images
