Connect ZWO Asiair to Avalon Linear (Stargo)
  • Daan
02 Nov 2019 13:34 #4 by Daan
Congrats on moving the forum from Yahoo to your own website and with respect to the new developments within Avalon :-)
I opened a topic in Yahoo yesterday with respect to connecting the Asiair to Stargo. I will copy/paste it to this forum:
"Am trying to figure out how to connect the recently purchased Asiair and which cable I would have to buy. USB to USB doesn't seem to work (however i've tested with a very old cable; might be a broken cable). According the shop where I purchased the Asiair it cannot be used on an Avalon mount but after checking with ZWO they informed me it should work. Does anybody use the Asiair on their Stargo mount? Statement made by ZWO:
It should be thru the RS232 serial cable. BUT, if the AVALON integrated the control system in the mount body likes the iOptron CEM40 does, yes, it could be thru the USB port on the mount. Maybe we need to contact the AVALON company to confirm that.
Have a nice day.
ZWO | Tech Support"
  • Daan
02 Nov 2019 13:35 #5 by Daan
Reply: Christopher Contaxis
Message 2 of 3 , Nov 1 4:12 PM
View Source
I don't own an ASI Air but I believe it works based off the INDI protocol. If that is the case it should work with the following driver indilib.org/devices/telescopes/avalon.html . You would just need to configure the ASI Air to start the avalon driver at the same time it starts up the ZWO camera driver.
  • Daan
02 Nov 2019 13:35 #6 by Daan
d.kleef
Message 3 of 3 , Today at 6:27 AM
View Source
Thanks for the reply. I'm not sure if the Asiair can be configured at all. I've tried different sequencies of connecting the mount and camera's by using an USB A to USB B cable. In a dropdown list of a menu in the Asiair app Avalon Stargo is indeed listed. However no luck yet to connect to the mount. The app crashes upon trying to establish a connection. So most likely I would need to connect the Asiair by using the by ZWO supplied RSR232 serial cable (RS232 male to USB A) . Does anybodyknow which cable I would have to buy and where to buy it (RS232 female to RJ45 male I would assume?)
  • Luciano Dal Sasso
02 Nov 2019 14:21 #7 by Luciano Dal Sasso
Replied by Luciano Dal Sasso on topic Connect ZWO Asiair to Avalon Linear (Stargo)
The StarGO USB port is based on the FTDI chip and the ASIair seems to be based on Raspberry/Raspbian/Ubuntu OS, so it is important that the FTDI driver must be installed on the ASIair in order to be able to connect with the StarGO via USB, by using the Avalon INDI protocol that you can download here:
Anyway we will test the ASIair within the next few days, so we will let you know about
Luciano
The following user(s) said Thank You: Daan
  • Daan
02 Nov 2019 14:41 #8 by Daan
FYI. This the link to the topic on the ZWO forum:
bbs.astronomy-imaging-camera.com/viewtopic.php?f=33&t=10263
  • sterne-jaeger
  • sterne-jaeger's Avatar
02 Nov 2019 17:28 #9 by sterne-jaeger
Replied by sterne-jaeger on topic Connect ZWO Asiair to Avalon Linear (Stargo)
Hi Daan,
similar as Chris I do not own a ZWO Asiair, but I am using the Avalon INDI driver on a Raspberry PI with my Avalon Linear now for almost two years. Simply plug the white USB cable that you get with your Avalon into the Asiair and everything should work. At least I never had problems with it.
Could you provide log files - or at least more details what "crashing" means?
- Wolfgang
TSA-120 + FSQ-85 + GSO 150/750 | Avalon Linear + M-zero | Moravian G2-8300 + ASI 1600mm pro + ASI 294mc pro | INDI/Kstars on Raspberry Pi 4 with Raspbian 10
Copyright ©2020 www.avalon-instruments.com - Design by Top 10 Binary Options
f t g m
Avalon Instruments
 Registered Office:
Via Angelo Secchi 8, Roma
Headquarter:
Via Pontina Vecchia KM 38,500 - Aprilia (LT)
CF/P.IVA 14949111000
Tel. 06 87153197
Terms of service
Secure Payment
paypal credit card images
