Solved Can StarGo be configured as Wifi client?
  • ken.self
  • ken.self's Avatar Topic Author
07 Nov 2019 20:39 - 22 Apr 2020 10:18 #33 by ken.self
I've got the StarGo wifi version and can connect to it with my PC but only by treating it as a network host. But that means I have to disconnect the PC from my home Wifi network and therefore cannot connect to the internet.
Is it possible to configure the StarGo WiFi to instead connect to my home network as a client?
Last edit: 22 Apr 2020 10:18 by Stefano82.
The following user(s) said Thank You: jg
  • Luciano Dal Sasso
08 Nov 2019 20:26 #38 by Luciano Dal Sasso
Replied by Luciano Dal Sasso on topic Can StarGo be configured as Wifi client?
The StarGO WiFi chip use the ad-hoc protocol , that works in the peer to peer mode and it cannot works as a client
Clear skies
  • ken.self
22 Nov 2019 05:48 #49 by ken.self
Replied by ken.self on topic Can StarGo be configured as Wifi client?
Hi Luciano
Are you sure about htis?
In Windows 10 if I run this command
netsh wlan show networks
StarGO_319 shows up as Infrastructure
Interface name : WiFi
There are 5 networks currently visible.
SSID 1 : StarGO_319
    Network type            : Infrastructure
    Authentication          : WPA2-Personal
    Encryption              : CCMP
<snip>
Likewise from Ubuntu
sudo iwlist scan
results in
wlan0     Scan completed :
          Cell 01 - Address: 00:06:66:9E:89:F6
                    Channel:1
                    Frequency:2.412 GHz (Channel 1)
                    Quality=50/70  Signal level=-60 dBm
                    Encryption key:on
                    ESSID:"StarGO_319"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
                              9 Mb/s; 12 Mb/s; 18 Mb/s
                    Bit Rates:24 Mb/s
                    Mode:Master
                    Extra:tsf=0000000000000000
                    Extra: Last beacon: 76ms ago
                    IE: Unknown: 000A53746172474F5F333139
                    IE: Unknown: 010802040B160C121824
                    IE: Unknown: 030101
                    IE: Unknown: 2A0100
                    IE: IEEE 802.11i/WPA2 Version 1
                        Group Cipher : CCMP
                        Pairwise Ciphers (1) : CCMP
                        Authentication Suites (1) : PSK
                    IE: Unknown: 320130
Mode: Master indicates that the StarGo is operating as an access point
01 Dec 2019 22:43 #57 by jg
Hi Ken,
I can't keep a consistent Wifi connection with StarGo - this is despite returning it to Avalon for repairs to the Wifi card. It works well for a couple of minutes then drops out and then reconnecting is usually impossible without power-cycling StarGo & PC.
Have you set-up a Host-only network? Does this maintain a constant Wifi connection with StarGo? If so, it would be great to read some tips on how you have configured things.
Thanks, Jason.
02 Dec 2019 15:59 - 03 Dec 2019 12:36 #61 by Stefano82
Replied by Stefano82 on topic Can StarGo be configured as Wifi client?
Hi Jason we need to know wich is the device that you are you using for the connection to the StarGO.
We suggest anyway some tips to improve the StarGO Wi-Fi connection and avoid noisy disconnection.
1 - First of all, on your device, disable all the automatic connection option with all your usual Wi-Fi networks, this is important because, in case of loosing/decreasing connection quality, the Wi-Fi connection protocol always search for more powerful wifi networks, at this point the connection with the StarGo is lost, that's why it is better to let only the StarGo Wi-Fi connection as automatic (if your device allows this option).
2 - Then if you are using Skysafari be aware that, when you set the "Set Time & Location", the connection needs exactly 60 seconds to be established. As this option it is only needed to update the location position, it is better to set it only once, then after the connection it is better to uncheck it, so after this, the connection will takes only a few seconds.
Last edit: 03 Dec 2019 12:36 by Stefano82.
03 Dec 2019 10:42 #64 by jg
My PC runs Win 7 Enterprise 64-bit.
Connecting to my iPadAir for visual is when I would most like Wifi connection to work. Generally I am unable to connect via iPad (running 12.4.2 at present) and on the rare occasions I have succeeded it drops out after a couple of minutes at most. I have attached screen shots from my iPad showing connection to StarGo wifi, but inability to connect via SkySafari 5. .
And the SkySafari settings:
