Translation by Google translate
Solved StarGo2 Firmware
  • JethroXP
02 Jan 2022 17:27 #841 by JethroXP
StarGo2 Firmware was created by JethroXP
I'm currently using the 1.7.20211109.174650 SM firmware version with my StarGo2 and M-due mount. When I look at the main support page, I only see download links for the original StarGo device. Is there a download location available for StarGo2 firmware updates?
08 Jan 2022 17:20 #847 by Planet30
Replied by Planet30 on topic StarGo2 Firmware
Thank you for this post!
Indeed, it would be very practical to see the latest version directly including the change log. I would not mind logging into a special section in case Avalon likes to keep track of who was downloading it.
The following user(s) said Thank You: JethroXP
  • c.granwehr@bluewin.ch
15 Jan 2022 21:40 #851 by c.granwehr@bluewin.ch
Replied by c.granwehr@bluewin.ch on topic StarGo2 Firmware
Where can I download version 1.7 for m-due?
  • JethroXP
16 Jan 2022 19:27 #854 by JethroXP
Replied by JethroXP on topic StarGo2 Firmware
Luciano from Avalon sent me a link to download it from Dropbox. I was going to share that link with you, but I just tried and it's no longer active. That why I started this thread, to find, or encourage the creation of, a definitive download location for current and past versions of the StarGo2 firmware.
The following user(s) said Thank You: Olivier31
17 Jan 2022 19:19 #856 by c.granwehr@bluewin.ch
Thanks. For version 1.5 the download was also only published in this forum. It is really uncomfortable to check the forum for new updates. A simple download list for available versions with additional notes should be normal.
  • Avalon Instruments Team
21 Jan 2022 17:01 - 31 Mar 2022 08:05 #861 by Stefano82
Replied by Stefano82 on topic StarGo2 Firmware
I would like to inform you that is now available the StarGo2 Pro download page in the Support Area, where it is possible to find the files required for the StarGo2 Pro system update.
You can visit this area by clicking on the link below.
www.avalon-instruments.com/support-2/support/category/5-stargo2
Last edit: 31 Mar 2022 08:05 by Stefano82.
The following user(s) said Thank You: JethroXP, Planet30, zubajohn
