Chinese simplified English French German Italian Spanish
Translation by Google translate
Solved Cant start StarGO 6.2.0 SP1
  • Dane
  • Dane's Avatar Topic Author
27 Dec 2019 14:55 - 22 Apr 2020 10:00 #97 by Dane
Cant start StarGO 6.2.0 SP1 was created by Dane
Hi
I have installed StarGO 6.2.0 SP1 and the latest Ascom driver. I get the following error message when starting StarGo:
How can I fix this?
_________________
Last edit: 22 Apr 2020 10:00 by Stefano82.
  • Luciano Dal Sasso
  • Avalon Instruments Team
27 Dec 2019 20:45 #98 by Luciano Dal Sasso
Replied by Luciano Dal Sasso on topic Cant start StarGO 6.2.0 SP1
Hi Dane
Which is your Windows version?
Did you run the installer as administrator?
Try to run the ocxFx.exe tool that you can find in the StarGO folder
Luciano
  • Dane
27 Dec 2019 23:27 #99 by Dane
Replied by Dane on topic Cant start StarGO 6.2.0 SP1
Hi Luciano
I have Windows 10 Pro 64bit and i run the installer as administrator. I install it for a second time as administrator, but nothing changes. I also startet the ocxFx.exe two times as administrator, but it doesent fix it. The same problem still exists.
_________________
  • Luciano Dal Sasso
29 Dec 2019 16:55 #101 by Luciano Dal Sasso
Hi
Try to use the new ocxFx.exe that you can download from the following link:
www.dropbox.com/s/22bsnv85sstlqlt/ocxFx.exe?dl=0
Run it as administrator
Luciano
  • Dane
29 Dec 2019 18:33 #102 by Dane
Same problem like before. I ave the same error message.
_________________
31 Dec 2019 08:10 #107 by Stefano82
Replied by Stefano82 on topic Cant start StarGO 6.2.0 SP1
Hi Dane.
We are working on this issue.
We suppose could be a conflict with some your installations.
As long as we are able to fix it we suggest you to come back to StarGo 5.6.6 version.
As we have news about it we will soon contact you.
The following user(s) said Thank You: Dane
