- Thank you received: 2
wsuyker wrote: Thank you, Stefano!
The straightforward pinout indicated above works! However, the motor is much more noisy, generating more vibrations than when used with the M-Uno mount. Can this be optimized somehow? I use the standard "advanced" StarGo parameters. Or could it be that there is an even more efficient wiring/ pinout connection? Or is this the result of the Pegasus box parameters and not correctable?
Thank you, Willem
