Solved Tracking with Losmandy HQ motor kit
  • starsherpa
22 Apr 2025 06:27 #1370 by starsherpa
Tracking with Losmandy HQ motor kit was created by starsherpa
Thank you for allowing me access to support. I have aquired the Stargo stand alone controller with the Losmandy HQ motor kit for my G11 mount second hand and I am attempting to do the necessary updates.  While using the product with the older version I have seen extremely poor  tracking performance both with the keypad only control and with the PC software.  It is my impression that the tracking is much too  fast in RA and reversing the direction does not solve the problem. My location data is good I believe, as is my polar alignment.
My current version of Stargo is 7.0.3
Firmware version 5.6.6
Ascom V.7.0.0.30
Losmandy HQ equatorial (G11 HQ motor kit)
It is asking me to update to V 7.0.0 firmware. I wanted to make sure what is the highest version my 10 year plus Stargo standalone controller can support. I will read thread on firmware upgrade installation procedure. I didn't want to risk losing all functionality until I was able to make contact here for support.
To eliminate contribution of the problem from the mount itself I have timed the rotations of the large pulley on my RA motor kit driving the RA worm both under load and with the coupler open. One rotation is fairly consistently 1 minute and 53 seconds. though it will vary a second or so. Should that not be 2:00 minutes for a 1440 (2 rotations per worm cycle?) what might be causing the rate to be that much too fast? is this related to out of date firmware in any way?
My experiments were over 6 worm cycles and done with the keypad only no pc software running but the same problem is seen running the pc software. I cant do tracking adjust because the error is too large to guide.
any thoughts?
22 Apr 2025 09:11 #1371 by Stefano82
Replied by Stefano82 on topic Tracking with Losmandy HQ motor kit
First of all we have noticed that the Software and Firmware are too old, so please download the Install_StarGo_640_SP8 from the page linked below, install it on your PC and upgrade the firmware to the 6.4.0 version. www.avalon-instruments.com/support-2/sup...y/2-software-and-app Then you have to be sure that the Gear Ratio has been correctly selected on the StarGo software. So, after the Software/Firmware update, please make the following check: Click on the ADVANCED tab, select the Losmandy HQ option and then click on the Custom radio button. By clicking on the Custom button the GUI will display the "real" Gear Ratio. In this way you can be sure about the Gear Ratio that you mount is using to track (it should be 1440).
  • starsherpa
23 Apr 2025 02:43 #1373 by starsherpa
Replied by starsherpa on topic Tracking with Losmandy HQ motor kit
I made an error in haste and followed the prompt to receive firmware version 7.0.0 . My system now is running 7.0.0 and after loading the mount files for Losmandy HQ 1440 it tells me to use 6.4.0 (as you did,) clicking on the system tab and uploading firmware is not functional. The screen simply disappears. How might I roll back to 6.4.0 or otherwise make my unit functional for gear ratios of 1000 or above. Thank you for your help
  • starsherpa
23 Apr 2025 02:45 #1374 by starsherpa
I would also mention I repeated the bundled installation again and it deleted the previous version and installed but the firmware remains 7.0.0 not 6.4.0
23 Apr 2025 07:15 #1375 by Stefano82
Try the procedure shown in the video linked below for the Firmware update:
www.avalon-instruments.com/support-2/vid...6-stargo-loader-tool
Let us know if in this way you can fix it
  • starsherpa
23 Apr 2025 11:37 - 24 Apr 2025 06:46 #1376 by starsherpa
Yes, I was successful. I await some clear sky to test tracking. Thank you for your help.
Last edit: 24 Apr 2025 06:46 by Stefano82.
